NetWare Network Setup Procedures
0L3X-1XX
To use a NetWare network, it is necessary to perform the following procedures.
Specify the NetWare print service settings. (Optional equipment is required to print from a computer. For information on the optional products required, see
"Optional Equipment and System Requirements.") To specify the settings from the computer, use one of the following:
NWADMIN or PCONSOLE (Novell software provided with NetWare)
Canon utilities
Specify the protocol settings. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Canon utilities
Specify the settings of each computer you use for printing. (Optional equipment may be required for printing from computers, depending on the model of your machine. For information on the optional products required, see
It is recommended that you consult the administrator for the network you are using when performing the settings in steps 1 and 2.
To configure settings with software other than the control panel of the machine, NWADMIN, or PCONSOLE, TCP/IPv4 protocol must be supported by your network environment (IPv6 is not supported).
If you are using the imagePRESS Server, see the manual provided with the imagePRESS Server.
If you are using the imagePRESS Server, some functions are not available with this machine. For details, see the manual provided with the imagePRESS Server.
