e-ManualTopSite mapHelp
Category Top
Optional Equipment and System Requirements
Printing from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE 802.1X Authentication Settings
Selecting the IEEE 802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Setting the Waiting Time for Connection at Startup
Setting Up a Computer for Printing
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Mac OS X 10.5 - 10.8
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Top » Network » TCP/IP Network Setup Procedures » Setting Up a Computer for Printing » Printer Connection Method (WSD)
0L3X-1XR
The following procedure describes how to perform printing with WSD when using Windows Vista/Server 2008/7/Server 2008 R2/8/Server 2012.
If a dialog box appears while you are performing this procedure, enter a user name and password. For more information, see the documentation provided with Windows Vista/Server 2008/7/Server 2008 R2/8/Server 2012.
The procedure for checking whether the IPv4 address of the computer to install the driver in is allowed in the [Firewall Settings] of the machine is described in steps 13 to 14 of "TCP/IPv4 Settings."
If communication via the relevant IPv4 address is not permitted in [Firewall Settings], you cannot install the driver.
After you have installed the driver, if communication via the IPv4 address of the computer you have installed it on is not permitted in [Firewall Settings], you cannot print from that computer.
Install the driver.
See the installation procedure for WSD network environment in the Printer Driver Installation Guide.
