e-ManualTopSite mapHelp
Category Top
Optional Equipment and System Requirements
Printing from a Computer
Using E-Mail/I-Fax
Sending Data
Checking Your Network Environment
Network Environment Setup Procedures
Connecting the Machine to a Computer or Network
Specifying Network Settings from the Touch Panel Display
Interface Settings
Communication Environment Setup
IEEE 802.1X Authentication Settings
Selecting the IEEE 802.1X Authentication Method
TCP/IP Network Setup Procedures
Protocol Settings
TCP/IPv4 Settings
TCP/IPv6 Settings
Settings Common to TCP/IPv4 and TCP/IPv6
Confirming TCP/IPv4 Settings (PING Command)
Confirming TCP/IPv6 Settings (PING Command)
Setting the Key Pair Used With SSL Encrypted Communications
IPSec Settings
Registering a Security Policy
Editing a Security Policy
Setting the Waiting Time for Connection at Startup
Setting Up a Computer for Printing
Printer Connection Method (LPD/Raw)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Mac OS X 10.5 - 10.8
UNIX
Printer Connection Method (IPP/IPPS)
Printer Connection Method (FTP)
Printer Connection Method (WSD)
Setting Up a Computer as a File Server
FTP Server Settings
WebDAV Server Settings
NetWare Network Setup Procedures
NetWare Print Service Settings
Setup Using NetWare Administrator or PCONSOLE
Protocol Settings
SMB/CIFS Network Setup Procedures
Protocol Settings
Connecting to a TCP/IP Network
Connecting to an SMB/CIFS Network
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
AppleTalk Network Setup Procedures
Protocol Settings
Network Connection Problems and Remedies
Printing Problems and Remedies
Data Sending/File Sharing Problems and Remedies
Encrypted SSL Data Communication Problems and Remedies
Confirming Settings
Checking the Block Log
Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012
Top » Network » Network Environment Setup Procedures
0L3X-1WK
Before using the machine in a network environment, it is necessary to perform the following setup procedures.
1 Connecting the Machine to a Computer or Network
Connect the machine to the network using the network cables.
2 Interface Settings
Specify the interface settings for communication between the machine and computers on your network. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
3 Communication Environment Setup
Set up the environment for communication between the machine and computers on your network.
4 IEEE 802.1X Authentication Settings
Specify the settings of IEEE 802.1X authentication.
If you are using the imagePRESS Server, see the manual provided with the imagePRESS Server.
If you are using the imagePRESS Server, some functions are not available with this machine. For details, see the manual provided with the imagePRESS Server.
