(Main Menu) → [Fax].
(numeric keys).|
Examples:
7:05 a.m. → 0705
11:18 p.m. → 2318
If you make a mistake when entering the send time, press
(Clear) to clear your entry → enter another four digit number.You can only cancel delayed send jobs from the Status Monitor/Cancel screen. (See "Canceling a Job.")
You can reserve up to 120 jobs for delayed sending. However, the actual number of send jobs that the machine can handle may be less than 120, depending on the following conditions:
When multiple documents are being sent at the same time.
When large documents are being sent.
When a large amount of memory is being used for the Mail Box and Fax/I-Fax Inbox.
The number of delayed send jobs you can reserve may also be reduced if other jobs with no Delayed Send settings are being processed, or if there are other factors affecting the specified destinations.
Once the delayed documents are sent, the documents are automatically deleted from memory.
You can check the status, cancel, or change the destinations of documents for which a preset send time has been specified.(See"Checking Job Status", "Canceling a Job", or "Resending Jobs/Changing Destination.")
