e-ManualTopSite mapHelp
Top » Adjustment for Image Quality and Finishing (Calibration) » Adjust Action » Changing the Finisher Output Priority Settings (Thin)
0L3X-0L0
When Thin paper 2 is used, you can give a priority to productivity or alignment for the output paper.
This mode can be set when the Finisher-AM1 or Saddle Finisher-AM2 is attached. (See "Finisher-AM1/Saddle Finisher-AM2/Puncher Unit-BS1/Puncher Unit-BT1.")
Press [Adjustment/Maintenance] → [Adjust Action] → [Finisher Output Priority Settings (Thin)].
Select [Productivity Priority] or [Alignment Priority] → press [OK].
Details of each item are shown below:
This mode gives a priority to productivity. The output paper may not be aligned.
As a priority is given to aligning the output paper, the production speed decreases compared with [Productivity Priority] mode.
[Alignment Priority] is available only when outputting on Tray B of a finisher.
