e-ManualTopSite mapHelp
Top » Adjustment for Image Quality and Finishing (Calibration) » Adjust Action » Perfect Binding Finishing Size Fine Adjustment
0L3X-0KL
You can make fine adjustments to the trimming width of the Perfect Binder.
This mode can be set when the Perfect Binder-D1 is attached. For information on the Perfect Binder-D1, see the manual provided with the optional product.
Press [Adjustment/Maintenance] → [Adjust Action] → [Fine Adjust Perfect Binding Finishing Size].
Press [-] or [+] to adjust the trimming width → press [OK].
You can switch between positive and negative values by pressing [±].
If you are making an adjustment in either the horizontal or vertical (top + bottom) direction, press [-] or [+] to enter a value for that direction only.
