e-ManualTopSite mapHelp
Top » Adjustment for Image Quality and Finishing (Calibration) » Adjust Image Quality » Adjusting Drum Temperature
0L3X-0K7
In a high-temperature or high-humidity environment, partial distortions, or thin white lines may appear on printed images.
You can prevent this problem by adjusting the photoconductor drum temperature.
Be sure to contact your local authorized Canon dealer before adjusting the photoconductor drum temperature. Increasing the drum temperature may cause the developer to deteriorate.
Press [Adjustment/Maintenance] → [Adjust Image Quality] → [Adjust Drum Temperature].
Select [Standard] or [High].
Details of each item are shown below.
[Standard]:
The default setting.
[High]:
Increases the temperature of the photoconductive drum.
4.
Press [OK].
