e-ManualTopSite mapHelp
Top » Adjustment for Image Quality and Finishing (Calibration) » Adjust Image Quality » Uneven Gloss Correction
0L3X-0K6
When the temperature of the pressure belt rises excessively, uneven gloss may occur. This mode enables you to reduce the uneven gloss by adjusting the temperature rise level of the pressure belt.
This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Changing this setting may have an effect on the paper curl. If necessary, adjust the [Curl Correction Level] in Paper Type Management Settings. (See "Curl Correction for Each Paper Drawer.")
Increasing the value requires the machine to take a long time to control the temperature. This may result in a slight decrease of the machine's productivity.
Press [Adjustment/Maintenance] → [Adjust Image Quality] → [Correct Uneven Gloss].
Press [-] or [+] to set the level of temperature management → press [OK].
Increase the value to increase the control over excessive temperature rise.
