<Adjustment/Maintenance>
<Adjust Action>
<Adjust Action>
Only use 13" x 19", 12 5/8" x 17 11/16", 12" x 18", A3, B4, A4R, 11" x 17", LGL, or LTRR paper for the saddle stitch staple repositioning procedure.
Make sure to remove all output booklets from the booklet tray before performing the saddle stitch staple repositioning procedure.
Make sure to remove the paper that was used for adjustment.
Paper that is required for the saddle stitch staple repositioning procedure is automatically fed to the saddle stitcher unit by the machine.
<Adjust Action>
<Adjust Action>
<Adjust Action>
When the paper width is smaller than 10 1/8" (257 mm), double staple width is fixed <4_3/4">.
<Adjust Action>
<Adjust Action>
This mode is enabled only when using the following paper:
Paper size: The width for the feeding direction is 8 1/2" (215.9 mm) or less Paper type: Plain, Heavy 1, Color, Pre-punched Paper weight: 17 lb bond to 32 lb bond (64 g/m2 to 128 g/m2) If you select <Speed Priority>, stapled output paper may not be aligned due to the temperature, humidity, or characteristics of the paper type.
<Adjust Action>
<Adjust Action>
<Adjust Action>
If the alignment guide's position is too close to the paper, a paper jam or paper crease may occur. Make sure to perform fine adjustment of the alignment guide's position.
<Adjust Action>
You cannot align output paper in the following situations:
when using paper smaller than STMTR when using different size paper together If you set <Align Output Paper of Diff. Sizes (Diff. Widths)>to <On>, you can align output paper by paper width.
You can switch between positive and negative values by pressing <±>.
<Adjust Action>
when using paper smaller than STMTR when using different size paper together If you set <Align Output Paper of Diff. Sizes (Diff. Widths)to <On>, you can align output paper by paper width.
<Adjust Action>
<Adjust Action>
<Adjust Action>
<Alignment Priority> is available only when outputting on Tray B of a finisher.
<Adjust Action>
