Paper Size/Weight/Type
Size
Two Holes: LGL, LTRR, and Custom Size (7 1/8" x 7 1/8" to 11 3/4" x 17" (182 x 182 mm to 297 x 432 mm))
Three Holes: 11" x 17", LTR, EXEC, and Custom Size (9 1/2" x 7 1/8" to 11 3/4" x 17" (240 x 182 mm to 297 x 432 mm))
Weight
14 lb bond to 140 lb index (52 to 256 g/m2)
Type
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Tab, Bond, Letterhead, and Coated*
* Coated paper can be loaded from the insertion unit only.
Punch Hole Quantity, Hole Diameter
Two or Three Holes: 3/8" (8 mm)
Distance between Punch Holes
Two Holes: 2 3/4" (70 mm)
Three Holes: 4 1/4" (108 mm)
Punch Waste Tray Capacity*
Approximately 4,500 sheets
* The figure may differ, depending on the surrounding environment, paper type, and paper weight.
