Paper Size/Weight/Type
Size
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTR, LTRR, EXEC, STMTR, and Custom Size (5 1/2" x 7 1/8" to 13" x 19 1/4" (139.7 x 182 to 330.2 x 487.7 mm))
Weight
14 lb bond to 140 lb index (52 to 256 g/m2)
Type
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Pre-Punched, Transparency, Labels, Tab, Bond, and Letterhead
Paper Deck Capacity
3,500 sheets (20 lb bond (80 g/m2)), or 15 1/8" (385 mm) in height
Power Source/Maximum Power Consumption
120 - 127 V AC, 60 Hz, 2.2 A/480 W maximum
Dimensions
(W x D x H)
25 7/8" x 27" x 22 1/2" (656 x 686 x 570 mm)
Weight
Approximately 149.9 lb (68 kg)
Installation Space Including the Main Unit
(W x D)*1
Without the upright control panel
75 1/2" x 30 5/8" (1,917 x 779 mm)
With the upright control panel
83 1/4"*2 x 30 3/8" (2,113 x 770 mm)
*1 When the Booklet Finisher-V1 is attached, and the auxiliary tray is extended.
*2 To the right edge of the upright control panel in the rightmost position.
