      0WR6-0X0
      <Set Line>
      You can specify the settings of the line to use when sending/receiving faxes. These settings including fax numbers to use need to be specified for each line.
      Item
      Description
      You can specify settings for line 1.
      <Line 2>
      You can specify settings for line 2. The setting items are the same as those in <Line 1>.
      <Line 3>
      You can specify settings for line 3. The setting items are the same as those in <Line 1>.
      <Line 4>
      You can specify settings for line 4. The setting items are the same as those in <Line 1>.
      <Select TX Line>
      You can set the priority of a line to use for sending faxes as well as select a line that is not allowed to use.
      IMPORTANT:
      Even if you set to prohibit using <Line 1> for sending documents, <Line 1> is still used for fax information services.
      Setting Value
      <Line 1>: <Priority TX>, <Prohibit TX>
      <Line 2>: <Priority TX>, <Prohibit TX>
      <Line 3>: <Priority TX>, <Prohibit TX>
      <Line 4>: <Priority TX>, <Prohibit TX>
      DeviceAdmin: Yes
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
