Item
Description
<Paper Settings>
You can register the paper size and type for each paper source. This setting enables you to achieve the appropriate print results.
Setting Value
Configure the paper size and type for each paper source.
<Set> (→ ), <Custom Size> (→ ), <Details of Selected Paper> (→ ) <Set> <Thin 2 (14-15 lb bond)>, <Thin 1 (16 lb bond)>, <Plain 1 (17-20 lb bond)>, <Plain 2 (21-24 lb bond)>, <Plain 3 (25-28 lb bond)>, <Heavy 1 (29-34 lb bond)>, <Heavy 2 (35-40 lb bond)>, <Heavy 3 (56-60 lb cover)>, <Heavy 4 (61-66 lb cover)>, <Heavy 5 (67-80 lb cover)>, <Color (17-24 lb bond)>, <Recycled>, <Pre-Punched>, <Tab>, <Bond>, <Letterhead>, <Detailed Settings> (→
) <Custom Size>: Set <X>, <Y>, <S1> to <S5>. <Details of Selected Paper>: Displays the following information.<Name>, <Category>, <Basis Weight>, <Finish>, <Type>, <Color>, <Adjust Image Position>, <Adjust Creep Correction>
<Detailed Settings>Paper type selection dropdown list:
<All>: Displays all paper types. <Standard Type>: Displays only paper types under the Standard category. <Custom Type>: Displays only paper types under the Custom Paper category. <Sort List By>: <Registered>, <Name>, <Weight>
<Thin 2 (52-59 g/m2)>, <Thin 1 (60-63 g/m2)>, <Plain 1 (64-75 g/m2)>, <Plain 2 (76-90 g/m2)>, <Plain 3 (91-105 g/m2)>, <Heavy 1 (106-128 g/m2)>, <Heavy 2 (129-150 g/m2)>, <Heavy 3 (151-163 g/m2)>, <Heavy 4 (164-180 g/m2)>, <Heavy 5 (181-220 g/m2)>, <Heavy 6 (221-256 g/m2)>, <Color (64-90 g/m2)>, <Recycled (64-90 g/m2)>, <Pre-Punched (64-90 g/m2)>, <Transparency (151-180 g/m2)>, <Tracing (64-90 g/m2)>, <Labels (118-185 g/m2)>, <Tab (91-220 g/m2)>, <Bond>, <Letterhead (151-180 g/m2)>, <1-Sided Coated 1 (106-180 g/m2)>, <1-Sided Coated 2 (181-220 g/m2)>, <1-Sided Coated 3 (221-256 g/m2)>, <2-Sided Coated 1 (106-180 g/m2)>, <2-Sided Coated 2 (181-220 g/m2)>, <2-Sided Coated 3 (221-256 g/m2)>, <Postcard>, <Details> (→ )NOTE:
For more information on the available paper for each paper sources, see Specifications.
For more information on how to load paper, see Loading Paper.
If the displayed paper size is different from the loaded paper size, paper may not be loaded properly. For more information on loading paper, see Loading Paper.
If <Custom> is displayed as the paper size when you load standard sized paper, press <Custom Size>
<Cancel Settings>. The proper paper size will be detected automatically and displayed on the screen.DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: No Device Information Distribution Available: No |
<Paper Size Group for Auto Recognition in Drawer>
You can register the paper size group for each paper source to make the machine detect the loaded paper size automatically.
Setting Value
<All Sizes>, <A/B Size>, <Inch Size>, <A/K Size>
DeviceAdmin: Yes
<A5R/STMTR Paper Selection>
When A5R or STMTR paper is loaded in the paper drawer, you can set the size to use for the operation.
Setting Value
<A5R>, <STMTR>
DeviceAdmin: Yes
<B5/EXEC Paper Selection>
When B5 or EXEC paper is loaded in the paper drawer, you can set which paper size to use for the operation.
Setting Value
<B5>, <EXEC>
DeviceAdmin: Yes
<Paper Type Management Settings>
You can register various custom paper types, besides the default paper types registered in the machine.
Setting Value
<Thin 2 (52-59 g/m2)>, <Thin 1 (60-63 g/m2)>, <Plain 1 (64-75 g/m2)>, <Plain 2 (76-90 g/m2)>, <Plain 3 (91-105 g/m2)>, <Heavy 1 (106-128 g/m2)>, <Heavy 2 (129-150 g/m2)>, <Heavy 3 (151-163 g/m2)>, <Heavy 4 (164-180 g/m2)>, <Heavy 5 (181-220 g/m2)>, <Heavy 6 (221-256 g/m2)>, <Color (64-90 g/m2)>, <Recycled (64-90 g/m2)>, <Pre-Punched (64-90 g/m2)>, <Transparency (151-180 g/m2)>, <Tracing (64-90 g/m2)>, <Labels (118-185 g/m2)>, <Tab (91-220 g/m2)>, <Bond>, <Letterhead (151-180 g/m2)>, <1-Sided Coated 1 (106-180 g/m2)>, <1-Sided Coated 2 (181-220 g/m2)>, <1-Sided Coated 3 (221-256 g/m2)>, <2-Sided Coated 1 (106-180 g/m2)>, <2-Sided Coated 2 (181-220 g/m2)>, <2-Sided Coated 3 (221-256 g/m2)>, <Postcard>, <Details/Edit> (→
), <Duplicate> (→ ) <Details/Edit>: Displays the following information.<Name>, <Category>, <Basis Weight>, <Finish>, <Type>, <Color>, <Adjust Creep Correction>, <Adjust Image Position>
<Duplicate>: Enter the name after copying the original setting.NOTE:
You can edit only user-registered paper types.
You cannot change the detailed information for paper currently being used for copy/print jobs.
When you register the settings for the custom paper type, make sure to change its name. You cannot change the settings of the default paper types registered in the machine.
For more information on creep (displacement), see Making Booklets (Booklet Copying).
The value you set here becomes the default correction width when the selected paper type is used for saddle stitching with automatic <Creep Correction>.
DeviceAdmin: Yes
NetworkAdmin: No Can be set in Remote UI: Yes (Only <Name> in <Sort List By> cannot be specified) Device Information Distribution Available: No |
<Register Favorite Paper (Multi-Purpose Tray)>
If you always load the same size and type of paper in the multi-purpose tray, register it as <Favorite Paper> in advance. <Favorite Paper> can be called up from the screen which is displayed when loading paper. Registering Frequently Used Paper Size and Type for the Multi-purpose Tray
Setting Value
<P1> to <P30>: Select to register the setting.
<Register/Edit>: Register the setting. <Rename>: You can rename the registered settings. <Delete>: You can delete the registered settings. NOTE:
For information on paper types, see Specifications.
You can register paper types that are not listed in <<Paper Settings: Paper Type>>.
DeviceAdmin: Yes
<Multi-Purpose Tray Defaults>
This setting is useful if you always load the same paper size and type into the multi-purpose tray by registering the default paper size and type for the tray in advance.If the multi-purpose tray is registered as a paper source for receiving faxes, the paper loaded in the multi-purpose tray is always used for printing received faxes.
Setting Value
<Use Preset>: <Register> (→
)<Always Specify>: <Standard>, <Favorite Paper> <Register>: Specify the pape size and type.NOTE:
You can register paper types that are not listed in <Paper Settings: Paper Type>.
DeviceAdmin: Yes
<Register Custom Size>
You can register frequently used free sizes of paper. The paper sizes registered here are displayed on the paper size selection screen for the paper deck/drawer and multi-purpose tray. Registering Free Size Paper (Custom Size Paper)
IMPORTANT:
Confirm the contents to be deleted.
Setting Value
<Register> (→
), <Delete>, <Rename> <Register>: Ener the size <X> and <Y><S1> to <S5>: Select to register the paper size.
<Register/Edit>: Register the paper size.
<Rename>: You can rename the registered paper size.
<Delete>: You can delete the registered paper size.
NOTE:
You can also name buttons with no settings stored in them.
DeviceAdmin: Yes
