      0WR6-0K8
      <Encryption Settings>
      You can specify the settings related to the encryption algorithms available for the machine.
      Item
      Description
      <Prohibit Use of Weak Encryption>
      Select whether to restrict the use of weak encryption, or a key and certificate with weak encryption.
      Setting Value
      <On> (→), <Off>
      <Prohibit Use of Key/Certificate with Weak Encryption>: <On>, <Off>
      NOTE:
      This setting applies to functions such as IPSec, TLS, Kerberos, S/MIME, wireless LAN, and SNMPv3. The machine may not be able to communicate with devices that only support weak encryption.
      Even if the use of weak encryption is restricted, it may be allowed depending on the certificate (root certificate).
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
