      0WR6-0JW
      <Manage Personal Settings>
      You can specify settings for the personalization function to save various settings for each user and apply them at login.
      Item
      Description
      <Enable Use of Personal Settings>
      Select whether to enable users that are logged in to the machine to register their personal settings, such as the display language, accessibility settings, and the default screen after a login.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Action When Maximum Number of Users Exceeded>
      Select how the machine processes personal settings when the number of users for which the machine can save various settings exceeds the limit.
      Setting Value
      <Delete Oldest User Settings>, <Discard New User Settings>
      DeviceAdmin: No
      NetworkAdmin: No
      <Use Default Screen After Startup/Restoration>
      Select whether to enable each user to set the default screen.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
