      0WR6-0F5
      <USB Settings>
      If you want to use the machine with the USB device, activate the connection settings. Also, you can set whether to use the MEAP driver when connecting the USB device.
      Item
      Description
      <Use as USB Device>
      You can set whether to use the machine as a USB device.
      Setting Value
      <On>, <Off>
      NOTE:
      If the setting is <Off>, the machine cannot print and scan via USB connection.
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
      <Use MEAP Driver for USB Input Device>
      You can set whether to use the MEAP driver for USB input device connections.
      IMPORTANT:
      Depending on the type of MEAP application that uses device such as a keyboard or card reader, you may need to set this setting to <On>. To check whether you need to set this setting to <On>, see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      <Use MEAP Driver for USB Storage Device>
      You can set whether to use the MEAP driver for USB external storage.
      IMPORTANT:
      Depending on the type of MEAP application that uses USB external memory device, you may need to set this setting to <On>. To check whether you need to set this setting to <On>, see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      <Use USB Storage Device>
      You can set whether to allow the use of USB external storage devices.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
