      0WR6-08J
      Working with Files and Folders in the Advanced Box
      You can rename and delete files saved in the Advanced Box as well as add and delete folders.
      1
      Press <Access Stored Files> on the Main Menu. <Main Menu> Screen
      2
      Press <Advanced Box>.
      3
      Press <Shared Space> or <Personal Space>.
      <Up>
      Press to move to the upper level from the current one.
      <Advanced Box Details>
      Enables you to check the locations (URL) of the Shared Space and the Personal Space, and the available memory of the Advanced Box.
      <Edit Personal Space>
      Enables you to create, rename, and delete the Personal Space.Creating the Personal Space in the Advanced Box
      4
      Operate files and folders.
      Location currently displayed
      Displays the location (path) where files and folders of  are saved.
      Files and folders saved
      Displays whether files or folders are selected, icons indicating the file type or folder, names, file sizes, and saved dates/times.
      Press <Name> or <Date/Time> to sort files and folders by name or date/time. Switch between ascending and descending order using  or .
      When files are selected, numbered icons are displayed in the order you select the files. If you are printing multiple files at the same time, they are printed in that order.
      In the Shared Space, a folder named "folder" is prepared.
      Total number of files/folders and number of selected files
      Displays the total number of files and folders saved in  and the number of files in the selection.
      <Print>
      <Folder Operations>
      Press to create or delete folders.
      <Edit File>
      Press to rename or delete files.
      <Display Image>
      Displays the preview image of a file.
      <Details>
      Displays the size and the updated date/time of a file.
      <Clear Selection>
      Deselects all the files selected in .
      Display switch button
      Press <Up> to move to the upper level from the current one. To update the contents of the displayed screen, press <Update>.
      To change a file name
      To display the preview image of a file
      To check the detailed information of a file
      To delete a file
      To scan and save documents
      To create a folder
      To change a folder name
      To check the detailed information of a folder
      To delete a folder
