      0WR6-0AF
      Specifying MAC Addresses in Firewall Settings
      You can set whether to allow or reject communication with a device that has a specific MAC address.
      1
      Press .
      2
      Press <Preferences>  <Network>  <Firewall Settings>  <MAC Address Filter>.
      3
      Select <Outbound Filter> or <Inbound Filter>.
      To restrict data sent from the machine to a computer, select <Outbound Filter>.
      To restrict data received from a computer, select <Inbound Filter>.
      4
      Set <Use Filter> to <On>, select <Default Policy>, then press <Register>.
      For <Default Policy>, select <Reject> to only allow communication with devices that have a MAC address specified in <Exception Addresses> in the next step, or select <Allow> to reject communication with them.
      NOTE:
      If <Reject> is selected for <Default Policy>, the restrictions do not apply to sending to multicast or broadcast addresses.
      5
      Enter the exception addresses, and press <OK>.
      Specify the MAC addresses to designate as exceptions of the <Default Policy> option selected in the previous step.
      NOTE:
      To edit an exception address
      On the screen displayed in step 4, select the exception address that you want to edit, and press <Edit> to display the edit screen.
      6
      Press <OK>.
      7
      Press     <Apply Set. Changes>  <Yes>.
