      0WR6-07E
      Adjusting Density
      You can scan documents more clearly by manually adjusting the density according to the contents of the document you are using. For example, increasing the density enables you to easily read faint characters written in pencil.
      1
      Place the document. Placing Documents
      2
      Press <Scan and Send> on the Main Menu. <Main Menu> Screen
      3
      Specify the destination on the Scan Basic Features screen. Scan Basic Features Screen
      4
      Press <Options>  <Density>.
      5
      Adjust the density and press <OK>.
      Press  to decrease the density. Press  to increase the density.
      NOTE:
      To adjust the density of the background
      Pressing <Adjust> enables you to adjust the density of the background before sending/saving. You can clearly send/save documents with a colored background or thin documents such as newspapers whose characters and images on the back side are transparently visible. Pressing <Auto> enables you to automatically adjust the density.
      Pressing <Adjust> and then <Adjust Each Color> enables you to adjust the density for each color.
      6
      Press <Close>.
      7
      Press .
      Documents are scanned and sending/saving starts.
