      0WR6-0L8
      Discarding Trim Waste (Inner Booklet Trimmer-A1)
      Follow the procedure described in this section to discard trim waste from the Inner Booklet Trimmer-A1 that is installed in the optional Booklet Finisher-X1.
      1
      Open the front cover of the finisher.
      2
      Pull out the trim waste tray.
      Hold the trim waste tray handle and gently pull it toward you.
      Pull it out completely, supporting it with your hand.
      3
      Discard the trim waste.
      4
      Return the trim waste tray to its original position.
      Make sure to insert the trim waste tray as far as it will go.
      5
      Close the front cover of the finisher.
