      0WR6-0L1
      Discarding Punch Waste (Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO)
      Follow the procedure described in this section to discard punch waste from the Puncher Unit-BS1 that is installed in the optional Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO.
      1
      Open the front cover of the finisher.
      2
      Pull out the punch waste tray.
      Make sure that the guide (F-A2) is closed before pulling out the punch waste tray so that it does not block the punch waste tray. Paper Jams in the Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO
      Hold the punch waste tray handle and gently pull it toward you.
      Pull it out completely, supporting it with your hand.
      3
      Discard the punch waste.
      4
      Return the punch waste tray to its original position.
      Make sure to insert the punch waste tray as far as it will go.
      5
      Close the front cover of the finisher.
