      0WR6-0KX
      Replacing the Staple Cartridge in the Saddle Stitcher Unit (Booklet Finisher-V1)
      Follow the procedure described in this section to replace the staple cartridge in the saddle stitcher unit for the optional Booklet Finisher-V1.
      1
      Open the front cover of the finisher.
      2
      Pull out the saddle stitcher unit.
      3
      Pull the lever on the two staple cases toward you to remove them.
      4
      Remove the empty staple cartridge.
      Hold both sides at the top of the empty staple cartridge.
      Lift and pull out the empty staple cartridge.
      5
      Take out a new staple cartridge from the box.
      6
      Insert the new staple cartridge in the staple case.
      7
      Insert the two staple cases into the saddle stitcher unit.
      Make sure that the staple cases are firmly inserted.
      8
      Push the saddle stitcher unit back into the machine, and close the front cover of the finisher.
