      0WR6-0R2
      Paper Jams in the Multi-Purpose Tray
      Check the location of the paper jam on the touch panel display, and follow the procedure described in this section to clear the paper jam.
      Check before clearing paper jams
      If paper is loaded in the multi-purpose tray, remove the paper.
      When the optional Paper Deck Unit-E1 or POD Deck Lite-C1 is attached, separate it from the main unit.
      1
      Open the upper-right cover.
      2
      Remove the jammed paper from the upper-right cover.
      Remove the jammed paper.
      Close the upper-right cover.
      3
      Follow the instructions on the touch panel display.
      Resume the procedure that was interrupted.
