      0WR6-0KL
      Replacing the Staple Cartridge in the Stapler Unit (Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO)
      Follow the procedure described in this section to replace the staple cartridge in the stapler unit for the optional Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO.
      1
      Open the front cover of the finisher.
      2
      Pull out the staple case from the stapler unit.
      Pull it out by holding the green lever.
      3
      Remove the empty staple cartridge from the staple case.
      4
      Take out a new staple cartridge from the box.
      IMPORTANT:
      Remove the seal that holds the staples together after you place the staple cartridge into the staple case.
      5
      Insert the new staple cartridge.
      6
      Hold the green lever, and push the staple case back into the stapler unit until it is securely in place.
      7
      Close the front cover of the finisher.
