      0WR6-02C
      Specifying Paper Size and Type in the Multi-purpose Tray
      1
      Load the paper in the multi-purpose tray. Loading Paper in the Multi-Purpose Tray
      The screen for specifying the paper size and type is displayed.
      2
      Specify the paper size.
      NOTE:
      If you press <Favorite Paper> and register the frequently used paper size on buttons, you can call them up with a simple press. Registering Frequently Used Paper Size and Type for the Multi-purpose Tray
      When loading standard size paper
      When loading custom size paper
      3
      Press <Change> in <Paper Type>.
      4
      Select the paper type and press <OK>.
      NOTE:
      If the paper type loaded is not displayed, press <Detailed Settings> to select from a list.
      5
      Press <OK>.
      If a screen other than that for specifying the paper size and type is displayed
      If a message prompting you to adjust the paper guide is displayed, adjust the width of the paper guide again and press <OK>.
