Paper Size/Weight/Type
Size
11" x 17", LGL, LTR, LTRR, EXEC, STMTR, and Custom Size/Free Size (4" x 5 7/8" to 11 3/4" x 17" (100 x 148 mm to 297 x 431.8 mm)
Weight
14 lb bond to 140 lb index (52 to 256 g/m2)
Type*
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, and Coated
* Coated paper can be loaded from the insertion unit only.
The Eco (Staple-Free) mode cannot be used for heavy paper, transparencies, tracing paper, labels, tab paper, bond paper, letterhead, or coated paper.
You cannot staple transparencies, tracing paper, or labels. |
Capacity Per Tray
(Tray A)
No Collating/Collate/GroupLTR, EXEC, and STMTR: 250 sheets (or 1 7/8" (47 mm) in height)
11" x 17", LGL, LTRR: 125 sheets (or 1" (24 mm) in height)
Offset mode (Collate/Group)LTR and EXEC: 250 sheets (or 7/8" (47 mm) in height)
11" x 17" and LTRR: 125 sheets (or 1" (24 mm) in height)
Capacity Per Tray
(Tray B)
Capacity Per Tray
(Tray C)
No Collating/Collate/GroupLTR, EXEC, and STMTR: 3,000 sheets (or 16 5/8" (423 mm) in height)*1
11" x 17", LGL, and LTRR: 1,500 sheets (or 8 1/2" (216 mm) in height)
No Collating/Collate/Group mode with different paper sizes1,500 sheets (or 8 1/2" (216 mm) in height)
Offset mode (Collate/Group)LTR and EXEC: 3,000 sheets (or 16 5/8" (423 mm) in height)*1
Z-Fold mode (when the Document Insertion / Folding Unit-J1 is attached)11" x 17": 30 sheets
LGL and LTRR: 10 sheets
Corner Stapling and Double StaplingLTR and EXEC: 200 sets (or 16 5/8" (423 mm) in height), or total 3,000 sheets*2
11" x 17", LGL, and LTRR: 100 sets (or 8 1/2" (216 mm) in height), or total 1,500 sheets
Staple-Free (Eco)11" x 17" and LTR: 200 sets
*1 Thin (14 to 15 lb bond (52 to 59 g/m2)): 1,500 sheets (or 8 1/2" (216 mm) in height)
*2 Thin (14 to 15 lb bond (52-59 g/m2)): 100 sets (or 8 1/2" (216 mm) in height), or total 1,500 sheets
Max. Stapling Capacity/Available Staple Size*
Corner Stapling and Double StaplingLTR and EXEC: 65 sheets (24 lb bond (90 g/m2))
11" x 17", LGL, and LTRR: 30 sheets (24 lb bond (90 g/m2))
5 sheets (14 to 17 lb bond (52 to 64 g/m2))
4 sheets (17.3 to 21.7 lb bond (65 to 81.4 g/m2))
3 sheets (21.7 to 28 lb bond (81.5 to 105 g/m2))
Manual Staple65 sheets (24 lb bond (90 g/m2))
* When the standard staple cartridge is attached. (The maximum stapling capacity may vary, depending on the paper type and weight.)
Power Source/Maximum Power Consumption
From the main unit/176 W or less (including the Puncher Unit)
Dimensions
(W x D x H)
20 5/8" x 24 1/2" x 43 1/4" (525 x 623 x 1,099 mm)
When the auxiliary tray is extended
24 3/4" x 24 1/2" x 45 3/4" (627 x 623 x 1,163 mm)
Weight
Approximately 77.2 lb (35 kg)
Installation Space Including the Main Unit
(W x D)*1
Without the upright control panel
68 3/4"*2 x 30 5/8" (1,745 x 779 mm)
With the upright control panel
83 1/4"*3 x 30 3/8" (2,113 x 770 mm)
*1 When the auxiliary tray is extended.
*2 When the right cover of the main unit is opened.
*3 To the right edge of the upright control panel in the rightmost position.
