Item
Description
<Forced Secure Watermark/Document Scan Lock>
Secure Watermark/Document Scan Lock enables you to prevent information leakage. These functions can be set by administrator so that it is always reflected on the output by the general users. For instructions on how to configure the setting, see Embedding Invisible Text (Forced Secure Watermark)
IMPORTANT:
For information on the optional products required to use this function, see System Options.
The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
Setting Value
<Copy>: <Do Not Set>, <Forced Secure Watermark> (→
), <Forced Doc. Scan Lock> (→ ), <Sec. Watermark +Doc Scan Lock> (→![]() )<Access Stored Files>: <Do Not Set>, <Forced Secure Watermark>(→ ), <Forced Doc. Scan Lock> (→ ), <Sec. Watermark +Doc Scan Lock> (→![]() )<Printer>: <Do Not Set>, <Forced Secure Watermark> (→ ), <Forced Doc. Scan Lock> (→ ), <Sec. Watermark +Doc Scan Lock> (→![]() ) <Forced Secure Watermark Settings><Watermark>
<Watermark Type>: <COPY>, <INVALID> <CONFIDENTIAL>, <FILE COPY>, <TOP SECRET>, <*Custom> When you select <*Custom>, register the strings, or select from registered strings.
<Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Date> <Date Format>: <yyyy/mm/dd>, <mm/dd/yyyy>, <dd/mm/yyyy>, <yyyy.mm.dd>, <mm.dd.yyyy>, <dd.mm.yyyy> <Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Copy Set Numbering>
<Starting Number>: Enter the starting number. <Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Serial Number> <Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <ID/User Name> <Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Next> If you press <Next> when QR code is used and <Sec. Watermark +Doc Scan Lock> is selected, <Forced Document Scan Lock> is displayed. (→ ) <Forced Document Scan Lock>When TL code is used
<Doc. Scan Lock Information>: <Allow All>, <Prohibit All>
<Tracking Information> (→ )When QR code is used
<Allow All>, <Prohibit All> <Specify for Each Job>*: Enabled, Disabled * Displayed only when <Copy> is selected. <Tracking Information><Set>, <Do Not Set>
<Custom Characters>: Enter characters. <Password When Analyzing Embedded Info.>: <Do Not Set>, <Set> (→ ) <Password>: Enter the password. (7654321)DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<Printer Driver Watermark/Document Scan Lock>
If you set Printer Driver Secure Watermark, you can select whether to set the Secure Watermark function for each print job from printer drivers.
IMPORTANT:
If <Printer Driver Secure Watermark> and <Forced Secure Watermark> are set for a printer at the same time, Forced Secure Watermark is given priority.
Setting Value
<Do Not Set>, <Driver Secure Watermark> (→
), <Driver Doc. Scan Lock> (→ ), <Sec. Watermark +Doc Scan Lock> (→![]() ) <Printer Driver Secure Watermark Settings><Watermark>
<Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Date> <Date Format>: <yyyy/mm/dd>, <mm/dd/yyyy>, <dd/mm/yyyy>, <yyyy.mm.dd>, <mm.dd.yyyy>, <dd.mm.yyyy> <Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Copy Set Numbering> <Starting Number>: Enter the starting number. <Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Serial Number> <Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <ID/User Name> <Size>: <36.0 pt>, <54.0 pt>, <72.0 pt> <Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Next>
If you press <Next> when QR code is used and <Sec. Watermark +Doc Scan Lock> is selected, <Printer Driver Document Scan Lock> is displayed. (→
) <Printer Driver Document Scan Lock>When TL code is used
<Doc. Scan Lock Information>: <Allow All>, <Prohibit All> <Tracking Information> (→ )When QR code is used <Allow All>, <Prohibit All> <Tracking Information><Set>, <Do Not Set>
) <Password>: Enter the password. (7654321)NOTE:
If you have registered characters in <Register Characters for Page Numbering/Watermark> in <Function Settings>, you can select the characters from the list.
The Serial Number, which appears at the bottom left of the screen when you press
on the control panel, is printed.If a login service has been set, the Department ID and user name of the user who is currently logged in to the machine are printed.
The watermark <CONFIDENTIAL> is printed if a login service is not set.
If you want to use the Secure Watermark function for each job from the printer driver, on the [Printing Preferences] dialog box, click the [Finishing] tab → [Advanced Settings] → select [On] for [Secure Printing Function of Device]. For more information, see the on-line help for the printer driver.
DeviceAdmin: Yes
<Adjust Background/Character Contrast>
You can adjust the contrast value for the text and background when copying/printing with the Secure Watermark mode. The Secure Watermark effect can be tested by making a copy of a sample print. Specify the following settings in <Adjust Background/Character Contrast>.
<Relative Contrast>: Adjusts the relative contrast of the hidden text and the background. <Standard Value Settings>: Sets the density of the background. <Latent Area Density>: Sets the density of the text. This setting can be specified when the Secure Watermark function is available for use. IMPORTANT:
Load A3, A4, LTR, or 11" x 17" size regular or heavy paper when making sample prints.
Setting Value
<Relative Contrast>: -7 to 1 to +7
<Sample Print> <Print Settings> (→ )<Standard Value Settings> (→ )<Latent Area Density> (→ )<Initialize> <Adjust Background/Character Contrast: Print Settings><Background Pattern>: <None>, <Arabesque>, <Fans>, <Polka Dots>, <Stars>, <Mesh>, <Clouds>, <Cherry Blossoms>, <Leaves>
<Size>: <Small>, <Medium>, <Large> <Print Vertically>: Enabled, Disabled <White Letters on Colored Background>: Enabled, Disabled <Standard Value Settings>: 1 to 20 to 64<Sample Print>
<Print Settings> (→ ) <Latent Area Density>: 1 to 8 to 36NOTE:
The sample print includes the hidden text and the background for each relative contrast value.
The area within the frame on the sample print is the output sample for the currently set relative contrast value.
Adjust <Relative Contrast> while comparing the difference between <Standard Value Settings> and the current <Latent Area Density>, by referring to the sample print.
If you increase the value for <Relative Contrast>, the background gets denser, and if you decrease the value, the background gets lighter. When <White Letters on Colored Bkground.> is set, if you increase the value for <Relative Contrast>, the background gets denser, and if you decrease the value, the background gets lighter.
The setting range for the relative contrast value differs according to the standard value settings, as indicated below.
standard value 1: relative contrast value 0 to +7 standard value 4: relative contrast value -3 to +7 standard value 8 to 56: relative contrast value -7 to +7 standard value 60: relative contrast value -7 to +4 standard value 64: relative contrast value -7 to 0 If you increase the value for <Standard Value Settings>, the background gets denser, and if you decrease the value, the background gets lighter. When <White Letters on Colored Bkground.> is selected, if you increase the standard value, the background gets denser, and if you decrease the value, the background gets lighter.
When changing the adjustment area on the sample print for the relative contrast, specify settings for <Standard Value Settings>.
If you changed <Standard Value Settings>, adjust <Latent Area Density> so that the density of the inner square set in <Standard Value Settings> for the standard value sample print gets closer.
To set a background density that differs from the most even secure watermark image in the standard value sample print, it is necessary to adjust <Latent Area Density> to a density close to the background density.
If you increase the value for <Latent Area Density>, the text gets denser, and if you decrease the value, the text gets lighter. When <White Letters on Colored Bkground.> is selected, if you increase the value for <Latent Area Density>, the background gets denser, and if you decrease the value, the background gets lighter.
DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: No Device Information Distribution Available: No |
<Adjust TL Code>
You can adjust the size, density, and color of the dots for the TL code to be embedded in the document.
Setting Value
<Dot Size>: 1 to 4 to 7
<Dot Density>: <Standard>, <Rough> <Initialize> DeviceAdmin: Yes
<QR Code Print Position>
You can select the potision of a QR code.
Setting Value
<Top Left>, <Bottom Left>, <Top Right>, <Bottom Right>
DeviceAdmin: Yes
