Item
Description
You can specify settings for line 1.
<Line 2>
You can specify settings for line 2. The setting items are the same as those in <Line 1>.
<Line 3>
You can specify settings for line 3. The setting items are the same as those in <Line 1>.
<Line 4>
You can specify settings for line 4. The setting items are the same as those in <Line 1>.
<Select TX Line>
You can set the priority of a line to use for sending faxes as well as select a line that is not allowed to use.
IMPORTANT:
Even if you set to prohibit using <Line 1> for sending documents, <Line 1> is still used for fax information services.
Setting Value
<Line 1>: <Priority TX>, <Prohibit TX>
<Line 2>: <Priority TX>, <Prohibit TX> <Line 3>: <Priority TX>, <Prohibit TX> <Line 4>: <Priority TX>, <Prohibit TX> DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: Yes |
