Item
Description
<Saddle Stitch Staple Repositioning>
You can reposition the stapler of the saddle stitcher unit after clearing a staple jam, or after replacing the staple cartridge. Saddle stitch staple repositioning works by feeding several sheets of paper into the saddle stitcher unit and stapling them together.
IMPORTANT:
Only use A3, B4, A4R, 11" x 17", LGL, or LTRR paper for the saddle stitch staple repositioning procedure.
Make sure to remove all output booklets from the booklet tray before performing the saddle stitch staple repositioning procedure.
Make sure to remove the paper that was used for adjustment.
NOTE:
Paper that is required for the saddle stitch staple repositioning procedure is automatically fed to the saddle stitcher unit by the machine.
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in Remorte UI: No Device Information Distribution Available: No |
<Change Fold/Stitch Position>
If you are using the Saddle Stitch mode of the Booklet Finisher, and you notice that the saddle stitch position of the paper is not exactly in the middle of the booklet, you can make adjustments to the saddle stitch position to compensate for this error. Adjusting the Saddle Stitch Position
IMPORTANT:
If you want to adjust both the stitch position and the fold placement, adjust the stitch position first, and then adjust the fold placement. To adjust the fold position, see Adjusting the Saddle Stitch Folding Position.
If both the stitch position and the fold placement are in the center of the paper after adjusting the stitch position, the adjustment of the fold placement is not necessary.
Setting Value
<Change Fold/Stitch Position>: <Custom Size>, <A3, 11x17>, <B4, LGL>, <A4R, LTRR>
-2.00 mm to 0.00 mm to +2.00 mm, in 0.25 mm increments DeviceAdmin: Yes
<Adjust Saddle Stitch Fold Position>
If you are using the Saddle Stitch mode of the Booklet Finisher, and you notice that the folds of the paper are not exactly in the middle of the booklet, you can make adjustments to the saddle stitch fold placement to compensate for this error. This mode enables you to adjust the folding position without changing the stapling position. Adjusting the Saddle Stitch Folding Position
IMPORTANT:
If you want to adjust both the stitch position and the fold placement, adjust the stitch position first, and then adjust the fold placement. To adjust the stitch position, see Adjusting the Saddle Stitch Position.
Setting Value
DeviceAdmin: Yes
<Switch Finisher Puncher Mode>
You can set whether to give priority to the punching speed or to precision.
Setting Value
<Speed Priority>, <Precision Priority>
DeviceAdmin: Yes
You can adjust the folding positions of the paper when a folding mode such as C-fold or Z-fold is set.
<Time Until Stapling Starts in Stapler Mode>
You can set the time to start stapling after the paper is inserted in the slit when you use manual stapling. For more information about manual stapling, see Optional Equipment.
Setting Value
1 to 3 to 5 seconds
DeviceAdmin: Yes
