      0WR7-0K7
      <Password Settings>
      You can set the number of characters, expiration period, and complexity of passwords. These settings prevent simple passwords from being registered to increase security.
      Item
      Description
      <Prohibit Caching of Authentication Password>
      Select whether to prohibit caching of a password that is entered at login.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Display Warning When Default Password Is in Use>
      Select whether to display the screen for changing the password when the Administrator logs in to the machine using the default user name and password.
      Setting Value
      <On>, <Off>
      NOTE:
      If the password has expired, the screen for changing the password appears, regardless of this setting.
      DeviceAdmin: No
      NetworkAdmin: No
      <Allow Use of Default Password for Remote Access>
      Select whether to allow the default password to be used when logging in from the Remote UI.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      <Minimum Length Settings>
      You can set the minimum number of characters required when registering a password to prevent the simplification of passwords. When a password length is set, a user cannot be registered with a blank password.
      Setting Value
      <On> (→), <Off>
      <On>
      1 to 32 characters
      NOTE:
      This setting applies to personal authentication management, not to Department ID Management or PIN.
      DeviceAdmin: No
      NetworkAdmin: No
      <Validity Period Settings>
      You can set a password expiration period to force users to periodically change their password, in order to prevent the simplification of passwords.
      Setting Value
      <On> (→), <Off>
      <On>
      1 to 180 days
      NOTE:
      DeviceAdmin: No
      NetworkAdmin: No
      <Prohibit Use of 3 or More Identical Consecutive Char.>
      You can restrict the characters that can be used for passwords to prevent the use of simple passwords.
      Setting Value
      <On>, <Off>
      NOTE:
      DeviceAdmin: No
      NetworkAdmin: No
      <Use at Least 1 Uppercase Character>
      Setting Value
      <On>, <Off>
      NOTE:
      DeviceAdmin: No
      NetworkAdmin: No
      <Use at Least 1 Lowercase Character>
      Setting Value
      <On>, <Off>
      NOTE:
      DeviceAdmin: No
      NetworkAdmin: No
      <Use at Least 1 Digit>
      Setting Value
      <On>, <Off>
      NOTE:
      DeviceAdmin: No
      NetworkAdmin: No
      <Use at Least 1 Symbol>
      Setting Value
      <On>, <Off>
      NOTE:
      DeviceAdmin: No
      NetworkAdmin: No
