      0WR7-0K3
      <HDD Data Complete Deletion>
      You can completely erase unnecessary or previously deleted data from the hard disk. You can also select the mode and timing for erasing data from the hard disk. Removing Unnecessary Data from the Hard Disk
      Item
      Description
      <Hard Disk Data Complete Deletion>
      Select whether to automatically delete unnecessary data that remains in the hard disk.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Timing of Deletion>
      Select when to delete unnecessary data.
      Setting Value
      <During Job>, <After Job>
      DeviceAdmin: No
      NetworkAdmin: No
      <Overwrite Method for Deletion Mode>
      You can set the Deletion mode and how many times to erase the data.
      Setting Value
      <Once with 0 (Null) Data>, <Once with Random Data>, <3 Times with Random Data>, <DoD Standard>
      DeviceAdmin: No
      NetworkAdmin: No
