      0WR7-0K1
      <Import/Export>
      You can export data that are registered in the machine, such as address lists in the Address Book, user setting information, and other settings. You can also import the information exported from the machine or other Canon multifunction printers. Importing/Exporting the Setting Data
      Item
      Description
      <Import from USB Memory>
      You can import all the settings information from a USB memory device.
      Setting Value
      <USB Memory>: Select the file to import.
      <Store Import Result in Device>: <On>, <Off>
      <Store Import Result in USB>: <On>, <Off>
      <Decryption Password>: Enter the password.
      <Start Importing>: <Yes>, <No>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Export to USB Memory>
      You can export all the settings information into a USB memory device.
      Setting Value
      <Encryption Password>: Enter the password.
      <Start Exporting>: <Yes>, <No>
      DeviceAdmin: No
      NetworkAdmin: No
      <Import Result Report>
      Select to print a report of import results.
      Setting Value
      <Yes>, <No>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      <Restrict Import/Export from Web Service>
      Select whether to restrict import and export operations with Web applications other than the Remote UI.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
