Item
Description
<Register License>
Enter the license key for a system option that can be used on the machine. Installing System Options
DeviceAdmin: No
NetworkAdmin: No Can be set in the Remote UI: No Device Information Distribution Available: No |
You can print a report on Multifunctional Embedded Application Platform (MEAP), and also configure the settings related to TLS communication used when a MEAP application is used.
<Remote UI>
Select whether to use the Remote UI to operate the machine and change settings. Starting the Remote UI
Setting Value
<On>, <Off>
<Use TLS>: <On>, <Off> DeviceAdmin: No
NetworkAdmin: No Can be set in the Remote UI: No Device Information Distribution Available: Yes |
<Delete Message Board Contents>
Select to delete messages from the administrator that are displayed on the control panel. Displaying Messages from the Administrator
IMPORTANT:
When <OK> is displayed on a message board, press <OK> to operate the machine. To clear a message board that does not contain the <OK> button, you need to use the Remote UI.
Setting Value
<Yes>, <No>
DeviceAdmin: No
<Remote Operation Settings>
Select whether to enable the Remote Operation function. This function enables you to specify settings and process jobs from a computer by displaying the screen of the touch panel display on the computer screen.
Setting Value
<On> (→
), <Off> <On>: Enter the password.NOTE:
For information on functions and operating instructions, see the instruction manual of the Remote Operator's Software Kit on the Canon official Web site.
DeviceAdmin: No
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<Use ACCESS MANAGEMENT SYSTEM>
Select whether to use ACCESS MANAGEMENT SYSTEM. Using ACCESS MANAGEMENT SYSTEM
Setting Value
<On>, <Off>
DeviceAdmin: No
<Register/Update Software>
You can install system options/MEAP applications in the machine using the <Register/Update Software> function.
Setting Value
<Install Applications/Options> (→
), <Software Management Settings> (→ ) <Install Applications/Options>: <License Access Number> <Software Management Settings>: <Select Log Display> (→ ), <Test Communication> (→ ) <Select Log Display>: <Display Update Logs>, <Display System Logs> <Test Communication>: <Yes>, <No>DeviceAdmin: No
<Start Setup Guide>
You can follow the wizard instructions to configure the machine's initial settings. Setting up Using the Setup Guide
Setting Value
<Enable>: Starts Setup Gudie.
DeviceAdmin: No
