      0WR7-0J9
      <Hold>
      This section describes the Job Hold settings.
      Item
      Description
      <Use Hold Function>
      You can set whether to use the Job Hold function.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Time Until Hold Job Auto Delete>
      You can set the time that has to elapse before hold jobs are automatically deleted.
      Setting Value
      <0> (hr.), <1> (hr.), <2> (hr.), <3> (hr.), <6> (hr.), <12> (hr.), <1> (days), <2> (days), <3> (days), <7> (days), <30> (days)
      NOTE:
      If you change the current date and time on the machine, the time taken for the hold job to be automatically deleted is affected.
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Store PS/PDF Data to Hold>
      You can set to store PS/PDF data jobs, which are executed with LPR protocol, in the Hold Queue.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
