      0WR7-0J0
      <Access Stored Files Settings>
      You can register/change the settings to use when printing documents from <Access Stored Files> on the Main Menu.
      Item
      Description
      <Register/Edit Favorite Settings>
      You can register frequently used settings in a button of the machine for later use when printing. You can also assign your favorite name to a button and check registered settings.
      Setting Value
      Buttons where settings are to be registered: <M1> to <M9>
      <Register>, <Rename> (→), <Delete>, <Check Content> (→)
      <Rename>: Change a button name.
      <Check Content>: Check the registered settings.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Change Default Settings>
      You can change and register some scan settings of <Access Stored Files> on the Main Menu as default settings.
      Setting Value
      <Register>, <Initialize>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
