      0WR7-0H9
      <Limit New Destination>
      The destinations that can be specified when sending faxes or scanned documents can be restricted to those registered in the Address Book or one-touch buttons, those registered in <Favorite Settings> or <Send to Myself>, or those that can be searched on the LDAP server. When this function is enabled, users cannot specify destinations using alphanumeric character input. Restricting New Destinations
      Item
      Description
      <Fax>
      You can restrict the destinations you can specify when sending faxes.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
      <E-Mail>
      You can restrict the destinations you can specify when sending e-mails.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <I-Fax>
      You can restrict the destinations you can specify when sending I-faxes.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <File>
      You can restrict the destinations you can specify when saving in a file server.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
