      0WR7-0H0
      <Set Authentication Method>
      Item
      Description
      <Information Used for LDAP Server Authentication>
      You can specify the authentication method for accessing an LDAP server.
      Setting Value
      <Device Settings>: Uses the authentication information set in <Register LDAP Server> (Registering the LDAP Server). Further settings are not required for every user.
      <Device Login Auth. Info.>: Uses the authentication information used for logging in to the machine. Further settings are not required for every user.
      <Register Info. for Each User>: Uses the authentication information registered by each user of an LDAP server. Further settings are required for each user.
      NOTE:
      <Device Login Auth. Info.> is available only when using the same authentication information for logging in to the machine and accessing the LDAP server, and when using a login service which supports Integrated Authentication. For information whether the login service you are using supports Integrated Authentication, contact your local authorized Canon dealer.
      DeviceAdmin: Yes
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Information Used for SMTP Server Authentication>
      You can specify the authentication method for accessing an SMTP server.
      Setting Value
      <Device Settings>: Uses the information for SMTP server authentication set in the machine (<E-Mail/I-Fax Settings>  <Communication Settings>). Further settings are not required for every user.
      <Register Info. for Each User>: Uses the authentication information registered by each user of an SMTP server. Further settings are required for each user.
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Information Used for File TX/Browsing Authentication>
      You can specify the authentication method for accessing a file server.
      Setting Value
      <Standard>: Uses the information for file server authentication set in the machine (Registering Destinations in the Address Book). Further settings are not required for every user.
      <Device Login Auth. Info.>: Uses the authentication information used for logging in to the machine. Further settings are not required for every user. This setting is available under the following conditions.
      When using the same authentication information for logging in to the machine and accessing the file server.
      When using a login service which supports Integrated Authentication. For information whether the login service you are using supports Integrated Authentication, contact your local authorized Canon dealer.
      When Integrated Authentication is not disabled
      <Register Info. for Each User>: Uses the authentication information registered by each user of a file server. Further settings are required for each user.
      DeviceAdmin: Yes
      NetworkAdmin: No
