      0WR7-0FU
      <Scan Settings>
      Item
      Description
      <Timing to Raise Feeder Tray>
      You can select the timing for raising the feeder tray when scanning originals using functions such as Scan and Store, and Copy.
      Setting Value
      <When Start Is Pressed>, <When Original Is Placed>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
      <Feeder Jam Recovery Method>
      You can select whether scanning will start again from the first page of the document or the page of the document in which scanning was interrupted if a paper jam occurs in the feeder. You can use this mode when using the Copy, Scan and Store, Scan and Send, and Fax functions.
      IMPORTANT:
      This function is not available if you are directly sending faxes in the Direct Sending mode. If a paper jam occurs in the feeder when using this mode, the fax job will be canceled. You need to specify the send settings again.
      Depending on the location of a paper jam, it can be difficult to determine until which page of the document scanning has been complete. If you set <From Suspnd. Original> for <Feeder Jam Recovery Method> and you do not find until which page the document has been scanned, it is recommended that you cancel the job, and then execute it again.
      Setting Value
      <From 1st Page>, <From Suspnd. Original>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Set Detection of Feeder Multi. Sheet Feed as Default>
      You can set whether to display a message on the screen when multiple sheets are fed.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Scanner Noise Settings>
      You can set whether priority is given to scanning speed or to noise reduction when the document is scanned from the feeder.
      Setting Value
      <Speed Priority>, <Quiet>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Streak Prevention>
      You can set whether to detect and prevent streaks when scanning documents.
      Setting Value
      <On>, <Off>
      NOTE:
      When <On> is selected, extremely thin lines may be detected as streaks.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Speed/Image Quality Priority for B&W Scan>
      You can set whether priority is given to scanning speed or to image quality when performing black and white scanning from the feeder.
      Setting Value
      <Speed Priority>, <Quality Priority>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <LTRR/STMT Original Selection>
      You can designate the way the machine handles LTRR and STMT originals that are placed on the platen glass.
      Setting Value
      <Select Manually>: A screen enabling you to select the document size appears when scanning.
      <Use LTRR Format>: The machine always detects the document as LTRR.
      <Use STMT Format>: The machine always detects the document as STMT.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Remote Scan Gamma Value>
      You can set the gamma value to use when scanning color documents into your computer. Select the gamma value most suited to your computer settings so that you can print the document from your computer with the optimal density.
      IMPORTANT:
      When the <Scanner> is enabled, you cannot use <Copy> and <Scan and Store> functions.
      Setting Value
      <Gamma 1.0>, <Gamma 1.4>, <Gamma 1.8>, <Gamma 2.2>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Auto Online>
      You can set to automatically enable the remote scanner function when you press <Scanner> on the Main Menu screen.
      IMPORTANT:
      Setting Value
      <On>, <Off>
      NOTE:
      If the remote scanner function is enabled, scanning is not possible with <Copy> or <Scan and Store>.
      DeviceAdmin: Yes
      NetworkAdmin: No
      Can be set in the Remote UI: No
      <Auto Offline>
      If the machine is connected to a network that is online, scanning is not possible with <Copy> or <Scan and Store>. If you set <Auto Offline> to <On>, the machine automatically goes offline when the <Auto Reset Time> specified in <Preferences> has elapsed.
      Setting Value
      <On>, <Off>
      NOTE:
      If the Auto Reset mode is not set (the Auto Reset Time is set to <0>), the machine automatically goes offline after approximately two minutes.
      DeviceAdmin: Yes
      NetworkAdmin: No
