      0WR7-0F7
      <Accessibility>
      This section describes settings for improving accessibility, such as the speed of repetition when keys are held down, and the ability to reverse the contrast of the touch panel display.
      Item
      Description
      <Key Repetition Settings>
      You can set the amount of time before characters start repeating when you hold down a key on the touch panel display, as well as the interval between repetitions.
      Setting Value
      <Standard>, <Slightly Slow>, <Slow>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Reversed Display (Color)>
      You can invert the screen colors of the touch panel display. If you find it hard to read what is being shown on the touch panel display, try using this mode.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Enable Screen Magnification>
      You can set the machine to zoom in or out on some screens by pinching out or in.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
