      0WR7-0F3
      <Direct Connection Settings>
      Specify the settings for direct connection (access point mode).
      Item
      Description
      <Use Direct Connection>
      Specify whether to use direct connection (access point mode).
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
      <Access Point Mode Settings>
      Specify the settings for access point mode.
      Setting Value
      <Specify SSID to Use>: <On>, <Off>
      <SSID>: Enter SSID.
      <Specify Network Key to Use>: <On>, <Off>
      <Network Key>: Enter the network key.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
