      0WR7-0EU
      <DNS Settings>
      This section describes the DNS settings.
      Item
      Description
      <DNS Server Address Settings>
      Specify the DNS server address settings. Making DNS Settings
      Setting Value
      <IPv4>
      <Primary DNS Server>: Enter the server address.
      <Secondary DNS Server>: Enter the server address.
      <IPv6>
      DeviceAdmin: No
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <DNS Host/Domain Name Settings>
      Specify the host name and domain name of the machine. Making DNS Settings
      Setting Value
      <IPv4>
      <Host Name>: Enter the host name.
      <Domain Name>: Enter the domain name.
      <IPv6>
      <Use Same Host Name/Domain Name as IPv4>: <On>, <Off>
      <Host Name>: Enter the server address.
      DeviceAdmin: No
      NetworkAdmin: Yes
      <DNS Dynamic Update Settings>
      Specify whether to perform the automatic update when the mapping between the host name and IP address is changed on an environment such as DHCP. Making DNS Settings
      Setting Value
      <IPv4>
      <DNS Dynamic Update>: <On>, <Off>
      <IPv6>
      <Register Stateless Address>: <On>, <Off>
      <Register Manual Address>: <On>, <Off>
      <Register Stateful Address>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <mDNS Settings>
      Specify the mDNS settings.
      Setting Value
      <Use IPv4 mDNS>: <On>, <Off>
      <mDNS Name>: Enter mDNS name.
      <Use IPv6 mDNS>: <On>, <Off>
      <Use Same mDNS Name as IPv4>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
