      0WR7-09F
      Utilizing the Machine through Applications
      Print and scan by using applications from a mobile device connected to the machine. Various applications including those exclusive to Canon are supported. Use properly in accordance with your device, the application, and the situation.
      Printing/Scanning via Canon PRINT Business
      You can print from a mobile device and send a documents scanned on the machine to a mobile device. For more information on supported operating systems, detailed setting methods, and operations, see the Canon website.
      Printing by Mopria™
      The machine also supports Mopria™. Using Mopria™ enables you to print using common operations and settings even if manufacturers and models differ. For example, if you are using printers supporting Mopria™ made by multiple manufacturers or a printer supporting Mopria™ that is located in a place you are visiting, you can print without installing an application exclusive for each manufacturer or model. For more information on supporting models or operation environments, see http://www.mopria.org.
      Confirming Mopria™settings
