      0WR7-09C
      Connecting with Mobile Devices
      There are two methods to connect the mobile devices with the machine, "Connection by wireless LAN" and "Direct connection." Select a connection method in accordance with the communication environment and the device you are using.
      Connecting with Wireless LAN
      Just as connecting a computer to the machine, connect a mobile device to the machine via a wireless LAN router. Connecting to a Wireless LAN
      Connecting Directly
      Directly connect a mobile device to the machine wirelessly without using wireless LAN. It is possible to immediately connect to the machine wirelessly even outside of a wireless LAN environment. Connecting Directly (Access Point Mode)
      If you perform a direct connection, you cannot use a wireless LAN via a router.
