      0WR7-05S
      Sending Faxes Manually (Manual Sending)
      You can manually send fax documents after checking that the destination is ready to receive fax transmissions.
      1
      Place the document. Placing Documents
      When you want to send multiple pages, place documents in the feeder. If you place them on the platen glass, you can only send one page.
      2
      Press <Fax> on the Main Menu. <Main Menu> Screen
      3
      Press <On-Hook> on the Fax Basic Features screen. Fax Basic Features Screen
      4
      Enter the recipient's phone number.
      5
      Make sure that you hear the recipient or a high-pitched tone.
      6
      Press .
      Documents are scanned and sending starts.
      Manual Sending is not available in the following cases
      Any of the following scan settings are specified: <2-Sided Original>/<Different Size Originals>/<Erase Frame>/<Job Build>/<Delayed Send>/<Finished Stamp>
      <Limit Functions> is set to <Off> for any function when the machine is in the Department ID mode. Configuring the Department ID Management Settings
      To specify the scanning size of documents
      The scanning size of documents placed in the feeder is automatically set. To specify the size yourself, use the platen glass.
