      0WR7-05R
      Checking the Connection to the Recipient Before Sending (Direct Send)
      To successfully send faxes to the destination you intend, you can check beforehand that the recipient is connected and ready to start communication. As the machine bypasses memory when scanning documents, you can send faxes even if there is no memory available.
      1
      Place the document. Placing Documents
      To send multiple pages, place the document in the feeder. When the document is placed on the platen glass, only one page can be sent.
      2
      Press <Fax> on the Main Menu. <Main Menu> Screen
      3
      Specify the destination on the Fax Basic Features screen. Fax Basic Features Screen
      4
      Specify the scan settings as necessary. Basic Operations for Sending Faxes
      5
      Press <Options>  <Direct Send>.
      6
      Press .
      The machine dials the recipient's number. When the machine connects the call, documents are scanned and sending starts.
      The machine does not start sending when the recipient's line is busy.
      Direct Send is not available in the following cases
      Any of the following scan settings are specified: <2-Sided Original>/<Different Size Originals>/<Erase Frame>/<Job Build>/<Delayed Send>/<Finished Stamp>
      Multiple destinations are specified.
      <Limit Functions> is set to <Off> for any function when the machine is in the Department ID mode. Configuring the Department ID Management Settings
      To specify the scanning size of documents
      The scanning size of documents placed in the feeder is automatically set. To specify the size yourself, use the platen glass.
