      0WR7-052
      Embedding the "TOP SECRET" Text (Secure Watermark)
      When copying documents that include confidential information, you can embed invisible text such as "TOP SECRET" or "CONFIDENTIAL" to warn unauthorized users not to copy them. When copying a document that has already been copied, the embedded text appears across the entire page, preventing unauthorized copies of copies.
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Press <Secure Watermark>.
      5
      Select the type of characters and specify detailed settings as necessary.
      Embedding watermarks such as "TOP SECRET" or "CONFIDENTIAL"
      Embedding dates
      Embedding reference numbers
      Embedding serial numbers
      Embedding ID or user name
      6
      Specify the print settings for the watermark.
      Set the character format.
      Press <Background Pattern> to print dots or a mesh pattern in the background.
      Press <Print Vertically> to embed the watermark in the landscape orientation.
      Press <White Letters on Colored Background> to embed outline characters.
      NOTE:
      You can adjust the density of patterns and backgrounds. If you press <Adjust Background/Character Contrast>  <Sample Print>, a sample of the pattern and background is printed. Check the sample and press /to adjust the density.
      7
      Press <OK>  <Close>.
      8
      Press .
      Copying starts.
      You cannot change the density during output.
