      0WR7-04R
      Inserting Sheets When Copying Onto Transparencies
      When copying onto transparencies, you can prevent transparencies from sticking together by inserting sheets between transparencies. You can also print on inserted sheets.
      1
      Load transparencies and paper to insert.
      Load the transparency in the multi-purpose tray and the paper to insert in the paper drawer, and specify the paper size and type for the transparency and paper. Loading Paper
      NOTE:
      For information on the paper size available for transparencies, see Specifications.
      2
      Place the document. Placing Documents
      3
      Press <Copy> on the Main Menu. <Main Menu> Screen
      4
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      5
      Press <Transparency Cover Sheets>.
      6
      Select whether to copy on the insert sheet and specify the insert sheet.
      To copy onto the insert sheet, press <Print>. The image printed on the preceding transparency is printed on the insert sheet.
      To specify the size of the insert sheet, press <Change> in <Cover Sheet Size> and select the paper size.
      7
      Press <OK>  <Close>.
      8
      Press .
      Copying starts.
