      0WR7-04K
      Copying with the Image Repeated (Repeat Images)
      You can copy the same image repeatedly on one page. You can easily make address labels and coupons.
      Pay attention to the sizes of the document and the paper
      When making address labels, set a document that is the same size as a single label and manually select the paper size (Basic Copy Operations). For example, if you set a document that is the same size as the paper and perform image repeat, the image in the original size is repeated and the printed images may be partially cut off.
      Example of an incorrect setting: Placing a document that is the same size as the paper and repeating the image twice vertically and twice horizontally
      Example of a correct setting: Placing a document that is one-fourth the size of the paper and repeating the image twice vertically and twice horizontally
      *If the document size is smaller than the paper size, the desired output size may not be selected while auto select paper is set.
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Press <Repeat Images>.
      5
      Specify the number of times to repeat and press <Set Margins>.
      Specify the vertical and horizontal number of times to repeat respectively.
      When setting to <Auto>, the image is repeated automatically until the images fill the paper.
      6
      Set blank spaces between images and press <OK>.
      Enter the blank space width. If you want to set a different blank space width above the image, under the image, to the left of the image, and to the right of the image, press <Adjust Independently> to enter each width.
      7
      Press <OK> <Close>.
      8
      Press .
      Copying starts.
