      0WR7-047
      Attaching Characters Such As "CONFIDENTIAL" (Watermark)
      You can attach watermarks such as "CONFIDENTIAL" or "TOP SECRET" when copying. You can create new watermarks or use pre-registered watermarks.
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Press <Watermark>.
      5
      Set the print position for the watermark.
      Select printing position by pressing an arrow button or <Center>.
      NOTE:
      Adjusting the position finely
      Press <Set Details>, specify each setting, and press <OK>.
      You can finely adjust the horizontal and vertical position with <Fine Adjustment>. Press <X> for the horizontal position adjustment and <Y> for the vertical position adjustment, and enter the values to move the positions.
      You can specify the positions of watermarks on the front side and back side with <Position for 2-Sided Prints> when performing 2-sided copying. For example, when the watermark on the front side is in the lower-right position, selecting <Opposite to Front Side> causes the watermark on the back side to be printed in the lower-left, and selecting <Same as Front Side> causes the watermark on the back side to also be printed in the lower-right.
      6
      Select orientation of the document placed.
      As shown in the illustrations below, if the document is placed in the portrait orientation when facing you, select <Upright Image>, if placed in the landscape orientation, select <Sideways Image>.
      <Upright Image>
      <Sideways Image>
      7
      Specify the print settings for the watermark.
      Set the character format of the watermark.
      Select the watermark to be printed from <Watermark Type>.
      Creating a new watermark to print
      8
      Press <Set Details> and specify detailed settings as necessary.
      Specifying the pages to print the watermark on
      Adjusting the density of the watermark
      9
      Press <OK>  <Close>.
      10
      Press .
      Copying starts.
      Watermarks are not printed on the cover (Adding a Cover and Back Cover) or the insert (Inserting Interleaves and Tab Paper).
