      0WR7-044
      Attaching Page Numbers
      You can attach page numbers when copying. You can adjust the position for page numbers and also select the page format.
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Press <Page Numbering>.
      5
      Select the page number format.
      Select the page number format from the following.
      Page Numbers Only
      With Hyphens
      With Chapter Numbers
      With Page Total
      NOTE:
      If you select <With Chapter Numbers>
      To advance the chapter numbers such as "1-1, 1-2…2-1, 2-2…3-1, 3-2…," you need to set chapter title pages. Inserting Interleaves and Tab Paper
      6
      Select the page number position.
      Select the printing position by pressing the arrow buttons.
      NOTE:
      Finely adjust the page number position
      Press <Set Details>, specify each setting, and press <OK>.
      You can finely adjust the horizontal and vertical position with <Fine Adjustment>. Press <X> for the horizontal position adjustment and <Y> for the vertical position adjustment, and enter the values to move the positions.
      You can specify the positions of page numbers on the front side and back side with <Position for 2-Sided Prints> when performing 2-sided copying. For example, when the page number on the front side is in the lower-right position, selecting <Opposite to Front Side> causes the page number on the back side to be printed in the lower-left, and selecting <Same as Front Side> causes the page number on the back side to also be printed in the lower-right.
      7
      Select the orientation of the placed document.
      As shown in the illustrations below, if the document is placed in the portrait orientation when facing you, select <Upright Image>, if placed in the landscape orientation, select <Sideways Image>.
      <Upright Image>
      <Sideways Image>
      8
      Select the page number color and size.
      9
      Enter the starting page number.
      If you selected <Page Numbers Only> or <With Hyphens> in step 4
      Enter the starting page number using the numeric keys.
      If you selected <With Chapter Numbers> in step 4
      Press <Starting Number> and enter the chapter number in the left column and the starting page number in the right column using the numeric keys.
      If you selected <With Page Total> in step 4
      Press <Starting Number> and enter the starting page number in the left column and the total page number in the right column using the numeric keys. Pressing <Auto> with the right column blank enables the total page number to be counted automatically and printed.
      10
      Press <Set Details> and specify detailed settings as necessary.
      Specifying the number of digits to be printed
      Adding characters around the page number
      Including the cover and insert in the page count
      Specifying the range for printing page numbers
      11
      Press <OK>  <Close>.
      12
      Press .
      Copying starts.
      Page numbers are not printed on the cover (Adding a Cover and Back Cover) or the insert (Inserting Interleaves and Tab Paper).
